No pod OneAgent on EKS Fargate cluster
I’m using EKS Fargate, I have applied the kubernetes yaml: https://github.com/Dynatrace/dynatrace-operator/releases/download/v0.10.4/kubernetes.yaml and dynakube.yaml.
So the pods: dynatrace-operator, dynatrace-webhook and activegate work correctly, but the daemonset oneagent not have pod.
On Dynatrace dashboard I see only Kubernetes cluster details correctly, no data from oneagent because no have pod.
Has anyone had the same problem as me, how did you fix it?
Thanks for your time
Cheears
Mario
Hi @mariocandela try using this yaml:
apiVersion: dynatrace.com/v1beta1
kind: DynaKube
metadata:
  namespace: dynatrace
spec:
  apiUrl: YOUR TENANT APIURL
  tokens: "dynakube"
  skipCertCheck: true
  oneAgent:
    applicationMonitoring:
      useCSIDriver: false
  activeGate:
    capabilities:
      - routing
      - kubernetes-monitoring
      - dynatrace-api
    image: ""
    replicas: 2
    resources:
      requests:
        cpu: 500m
        memory: 512Mi
      limits:
        cpu: 1000m
        memory: 1.5Gi
    group: default
Describe output of the OA daemonset might give more insights of the issue and root cause of the missing OA pods.
