Node.js monitoring
HI Team,
In one of our applications (Node.js), some transactions are not getting captured automatically. What is the way to capture it? What I got to know from documents is that custom service detection is only available for Java php and .net.
Hi @Omkars,
Please make sure that the Nodejs version is supported
also, you can use OneAgent SDK for Nodejs for custom tracing capabilities.
you can share some screenshots that might help us to provide more details.
Mohamed
