I have installed one agent on a windows machine and performed SQL injection, Command injection but not able to fecth the attack logs on dashboard. I’m receving the logs and events (CPU, Memory & resource utilization).
If you are not seeing your log file, you may need to manually add it. Log ingest rules (Logs Classic) — Dynatrace Docs
