I have deployed OneAgent onto my Fargate container which is primarily running nginx and Flask/Python with uWSGI.
The container shows as a host through Hosts Classic fine.
- The application log file is written to /var/log/app/ as action.log which should meet the security criteria.
- The container root file system is read-only.
- A number of volumes and mount points have been added for
- logging nginx and uWSGI,
- OneAgent logs and datastorage,
- /tmp and
- /var/log/app directory structure.
Under the host I’m not seeing any automatically detected logs so have tried to add /var/log/app
I have added
- A custom log source, against the nginx log source context and path /var/log/app/*
- A log ingest rule for /var/log/app/action.log
Despite this I am still not able to see the logs being ingested in Logs & Events.
I do have logs ingesting from my EC2 hosts without issue.
Any help would be welcome.
Cheers
