we have Hash-Routing strategy enabled in our angular application so due to that we are not able to see different page(hash) names even after routing over multiples pages, hash name are not available in dynatrace’s user action.
Please suggest me how can i able to see hash name in dynatrace.
Hi @Islam_Zedan@radek_jasinski I have tried by changing different placeholder but in page group and pages section of dynatrace i am only able to see ‘/ah-angular’ as a page-group and page name.
You can click on preview on the end of the page to see the elements of your page and which element is getting the value you want. For the placeholder, you can create a new one that catch part of the url, then you can use it in the naming rule.
here is the screenshot as i have informed when hashing is off page name is visible but when ON only ‘/’ is visible as page name, but i want loading of page /home etc.
Under “settings>capturing>advanced setup>custom configuration properties” use the following options (without quotes) to change the way page change events are captured:
