Not seeing Database connection pool metrics in Cloud Foundry tomcat instances
I am not able to see = DB connection pool metrics in Cloud Foundry tomcat instances. Do we know how these can be monitored or enable in Dynatrace
Hi Vinnu,
I don’t believe that connection pool metrics are captured out of the box. You can configure them through the UI though. Go to Settings → Monitoring Technologies → Add new technology monitoring → Add JMX/PMI extension. See screenshot:
From there you can use the wizard to find the tomcat instance and then select the connection pool metric.
You can find the document for this feature here: JMX extensions — Dynatrace Docs
-Dallas
Hi Dallas,
we added the JMX Db2 plugin and we exposed JMX in our spring boot app. still we are not seeing JDBC pool metrics in dynatrace
Spring config on our app
endpoints:
jmx:
exposure:
include: “metrics, info, beans, conditions, health, loggers, mappings”
let me know what else need to be done to see these metrics
Vinnu
Hi Vinnu,
A few points to check:
  • You referred to a “Db2” plugin so first would verify you’re referring to one of these described here: AI-powered insights into connection pool performance
  • Second, this extension supports specific Mbeans/attributes that come along with connection pool implementations such as: Apache Tomcat 7 (7.0.109) - The Tomcat JDBC Connection Pool. A good one to check for to verify it can work would be to check that you can see Mbeans under the Catalina domain, with the type as “datasource.” You should see attributes such as ‘numActive.’ If you are using another connection pooling implementation e.g. Hikari it will not be covered by this extension. You can use the editor Dallas mentioned as a way to see if those attributes are discoverable. Any other means of checking Mbean values is also fine (e.g. Jconsole).
  • Lastly, I see a number of posts around the Web around how JMX can be disabled, it seem there are a lot for the Spring Framework specifically. If you are very confident your implementation meets the previous criteria this is where I would try to explore and ideally see if you can get the metrics exposed via JMX and checking via some means other than Dynatrace before looking to an issue within Dynatrace itself.
