Hi Community,
I have a Kubernetes cluster being monitored using Dynatrace. On that, I need to enable notification alerting when a Pod or Node auto scales. Can It be done through any custom events for alerting?
As I checked on the below link for built-in metrics. I couldn’t find a metric to achieve the requirement to monitor event for Pod or Node autoscaling.
Appreciate it if you guys can shed some light on how I can achieve this.
Thanks in Advance
Ref:
