Nutanix remote monitoring fails
As I try to configure Nutanix monitoring it fails with the error below,
Failed to assign monitoring configuration to ActiveGate. Reason: Python datasource fastcheck error: AttributeError(‘ERROR’)
Connectivity is good on the port. Any inputs on what is wrong and how to fix?
Hi @elpathi ,
How are you monitoring Nutanix infraestructure? Have you using a Dynatrace extension for Nutanix or is it a custom extension made in Python?
By default Dynatrace recognizes the hosts virtualized with Nutanix AHV.
(The hosts on my environment are swithed-off nowdays).
Then, you can add to your environment Nutanix cluster extension providing the Prism API URL.
And you have to select an ActiveGate that belong to an ActiveGate group.
Hope it helps.
Elena.
I had the URL incorrect I guess, its working now
