I am trying to use an OAuth client in Python
The following cURL command works:
curl --location --request POST 'https://sso.dynatrace.com/sso/oauth2/token' --
header 'Content-Type: application/x-www-form-urlencoded' --data-urlencode 'grant_type=client_credentials' --data-ur
lencode 'client_id=dt0s02.<ID>' --data-urlencode 'client_secret=dt0s02.<SECRET>' --data-urlencode 'resource=urn:dtaccount:<ACCOUNT>' -
-data-urlencode 'scope=<POLICIES SPACE SEPARATED>'
However, the following Python POST request gives me a 400 error.
headers = {
"Content-Type": "application/x-www-form-urlencoded"
data = {
"grant_type": "client_credentials",
"client_id": client_id,
"client_secret": client_secret,
"scope": scope,
"resource": resource
encoded_data = urlencode(data)
print(encoded_data)
bearer_token = requests.post(oauth_api_url, data=encoded_data, headers=headers, verify=False)
print(bearer_token)
Variables are all defined correctly same as values used in cURL command.
Can anyone see where I’m going wrong?
Thanks.
