We are trying to configure SAML SSO with Okta on Dynatrace Managed, but we can’t make it working. We followed this doc Manage users and groups with SAML in Dynatrace Managed | Dynatrace Docs
Where can we get any logs to analyise the issues?
I would verify the SSO logs in the first instance. There is probably a lack of proper configuration on its side.
You can find the DT logs here: /var/opt/dynatrace-managed/log/server/
Check the server file… , but I’m not sure there will be detailed information there.
Radek
