Once more the COR_ENABLE_PROFILING issue
Hello All,
Best wishes for 2026!!
It is a well known issue that Dynatrace does not like competitors (-;
… so oneAgent likes to overrule the COR_ENABLE_PROFILING set by other vendors…
Does anybody know if this only happens with FULL-STACK and DISCOVERY and not for INFRA mode?
And is there a better work-around than disable the OA?
KR Henk
Hi Henk,
Best wishes to you too!
Firstly: since you can opt-in AppSec on Infrastructure mode, I guess the code repositories and processes will somehow be affected here as well.
Haven’t tried this myself but since the COR_ENABLE_PROFILING is set for .NET at startup, have you tried disabling the monitoring of .NET processes and / or  disabling the agent injection in the host group / host setting?
Like I said, not 100% sure but it’s worth a try. I’m guessing the other competitor get’s privilege over Dynatrace in your scenario so hopefully you can still get Infrastructure mode or Discovery working?
Best regard,
Michiel
Hi Michiel,
Great answer!
(ga wel even verder pielen 😀)
Thx Henk
Good luck 💪
