I need your help with the install one agent on Solaris X86 system. I have already done all the processes such as the Extract file in /opt/dynatrace/oneagent but the part where I have to insert our code into a startup script.
Here is the problem our customer doesn’t use Weblogic or Websphere. They use Xampp so I don’t know where I can insert this code into, maybe in httpd.conf of Xampp also I have to use this line of code right ? not the Websphere one
DT_HOME=/opt/dynatrace/oneagent
export DT_HOME
LD_PRELOAD_64=$DT_HOME/agent/lib64/liboneagentproc.so
export LD_PRELOAD_64
LD_PRELOAD=$DT_HOME/agent/lib/liboneagentproc.so
export LD_PRELOAD
Do you guys have any idea on how to install one agent on Solaris that uses Xampp for their Webhost?
Best Regard
Thank You
