One more small question about AWS Dynatrace connection
See below setup screen:
So you have to generate your accountid once ? On the first create.
I assume you can bring your own?
The API also will accept the accountid once?
Can you add or delete these token(s)
Last on, all AWS connections on DT must share this one?
Use case:
Create your connection on a test/scratch environment and when it works deploy with the same parameters on PRD. (also could not find the disable switch, so you need to delete the settings on scratch/test)
KR HEnk
Hey @henk_stobbe !
Sorry for the delay. Our Community gets lots of activity every day, and unfortunately, sometimes, some posts don’t get as much attention as they deserve. Did you find an answer to your question, or would you like me to seek further assistance for you?
Hello Izabela,
Thanks for your reply, please do not seek further if nobody else is interested (-;
It has no consequences and it is just a “nice if anyone knows” question,
KR Henk
