OneAgent communication to ActiveGate through Proxy
Hello Folks,
How can we verify that, the OneAgent is communicating to ActiveGate through proxy.
I used --set-proxy-server command to set it.
AK
@AK Did you get a chance to check access log at proxy leve.. as i have used haproxy which communicated to AG through frontend and backend modules, and all request can be tracked through access log.
Sujit Singh
@AK,
I suppose you’re asking because you cannot get connectivity… If that’s the case, and if you have access to the server, do a netstat  with the PID option, (-p in windows, -o in Linux), check out the PID for the Oneagent processes, and check in what state the connections for these PIDs are. They should be in a socket with the proxy, but the netstat will tell you definitely what is happening.
