Hi Tomasz, thanks for your response.
However, I see the container (latest) still appears to have issues, the containers fail to startup due to a permissions issue in mounting the installation directory. Here is the container logs from kubernetes when deploying with “latest”:
bash-3.2$ kubectl logs dynatrace-oneagent-2q2jv
/tmp/entrypoint.sh: line 352: can't create /mnt/root//opt/dynatrace/oneagent/log/installer/installation_docker_26567.log: nonexistent directory
mkdir: can't create directory '/mnt/root//opt/dynatrace/': Read-only file system
07:07:47 Cannot create /mnt/root//opt/dynatrace/oneagent directory.
chmod: /mnt/root//opt/dynatrace/oneagent: No such file or directory
07:07:47 Cannot change permisions of /mnt/root//opt/dynatrace/oneagent directory to 755.
07:07:47 Cannot create /mnt/root//opt/dynatrace/oneagent/log directory.
chmod: /mnt/root//opt/dynatrace/oneagent/log: No such file or directory
07:07:47 Cannot change permisions of /mnt/root//opt/dynatrace/oneagent/log directory to 777.
07:07:47 Cannot create /mnt/root//opt/dynatrace/oneagent/log/installer directory.
chmod: /mnt/root//opt/dynatrace/oneagent/log/installer: No such file or directory
07:07:47 Cannot change permisions of /mnt/root//opt/dynatrace/oneagent/log/installer directory to 755.
07:07:47 Cannot create /mnt/root//opt/dynatrace/oneagent/log/network directory.
chmod: /mnt/root//opt/dynatrace/oneagent/log/network: No such file or directory
07:07:47 Cannot change permisions of /mnt/root//opt/dynatrace/oneagent/log/network directory to 755.
07:07:47 Started agent deployment as docker image, PID 26567.
07:07:47 Container version: 1.121.196.20170720-130455
07:07:48 Deploying to: /mnt/root
07:07:48 Cannot create /mnt/root//opt/dynatrace/oneagent directory.
07:07:48 Cannot change permisions of /mnt/root//opt/dynatrace/oneagent directory to 755.
cp: can't create '/mnt/root//opt/dynatrace/oneagent/Dynatrace-OneAgent-Linux.sh': No such file or directory
Here is my deployment .yaml:
apiVersion: extensions/v1beta1kind: DaemonSetmetadata: name: dynatrace-oneagentspec: template: metadata: labels: run: dynatrace-oneagent spec: hostPID: true hostIPC: true hostNetwork: true volumes: - name: host-root hostPath: path: / containers: - name: dynatrace-oneagent image: dynatrace/oneagent:latest args: - "TENANT=lfn20468" - "TENANT_TOKEN=IRV1c15bIcRWq5KQ" - "SERVER=https://lfn20468.live.dynatrace.com" volumeMounts: - mountPath: /mnt/root name: host-root securityContext: privileged: true
Snapshot of status of the daemonset:
bash-3.2$ kubectl get daemonsets
NAME DESIRED CURRENT READY UP-TO-DATE AVAILABLE NODE-SELECTOR AGE
dynatrace-oneagent 3 3 0 3 0 <none> 5m
bash-3.2$
bash-3.2$
bash-3.2$
bash-3.2$ kubectl get pods
NAME READY STATUS RESTARTS AGE
dynatrace-oneagent-2q2jv 0/1 CrashLoopBackOff 5 5m
dynatrace-oneagent-5mqv1 0/1 CrashLoopBackOff 5 5m
dynatrace-oneagent-6vvtf 0/1 CrashLoopBackOff 5 5m
