OneAgent deployment issues on Cloud Foundry for application-only monitoring
The Dynatrace integration for the Node.js buildpack allows you to successfully push your application even when the download of Dynatrace OneAgent fails (for example, because of a network connection error). You can configure OneAgent error handling via the option skiperrors that you can specify in the payload of the user-provided Cloud Foundry service that’s bound to your application:
<span>cf</span> <span>cups</span> <span>dynatrace-service</span> <span>-p</span> <span>"environmentid, apitoken, skiperrors"</span>
You’re prompted automatically to provide your environment ID, API token, and either true or false for the skiperrors flag. Note that, by default, an unsuccessful download of Dynatrace OneAgent will result in a deployment error.
