Ah, my VM would have restarted a few times before I installed DT, as I installed VM Guest additions. Glad someone reproduced it, I was beginning to doubt my sanity!
I did exactly what you did, used the dynakube.yaml as is, no modifications…strange. I’ll give it another go, thanks @andre_f
I usually use k3s instead of minikube. This works without problems. Perhaps you can give it a try.
Got this info, but have not been able to test it myself yet.
“We support only minikube started with --vm-driver=none parameter.
It’s recommended to use only docker runtime (it’s controlled by --container-runtime minikube’s parameter).”
I think ActiveGate can be run on Minikube by updating the nodeSelector in the ActiveGate StatefulSet from kubernetes.io/arch: amd64 to kubernetes.io/arch: arm64.
