@y_buccellato,
Thank you for your suggestions. Apologies for late comments on the topic. The host is not under our custody hence it is taking time to do test the installation.
I did the installation and it went successful however, I found few strange things and issues,
1. I tried to get the all OneAgent versions available for download in my environment using regular API token but it gave below error,
“error”: {
“code”: 403,
“message”: “Token is missing required scope. Use one of: InstallerDownload (PaaS integration - Installer download)”
Then I realize that, the normal API token will not work and I need to generate PaaS token to use those kind of APIs (Correct me if I’m wrong)
I generated a PaaS token and downloaded the installer for AIX - 1.173.314 and copied to concerned host. (The only difference I can observe from the regular steps is PaaS token in the command rather that API token and below is the GET URL I used to download
https://abc12345.live.dynatrace.com/api/v1/deployment/installer/agent/aix/default/version/1.173.314.20190809-152259?flavor=default&arch=all&bitness=all&skipMetadata=false&Api-Token=dt01.DJKDJKE.GPWCWNNTR
I ran the installer for 1.173.314 on the host and checked a agent version under host UI and it was 1.215.163
2. I checked with Chat support as how installed agent version is showing 1.215.163 when ran the installer for 1.173.314 in reply they asked “Are these host deployed to a PaaS environment?”
Now the question is,
1. Have I deployed the agent using PaaS deployment? (I’m not at all sure on this as I never did this kind of deployment)
If yes, what is the difference in regular and PaaS deployment and Is there a way to check the host which are deployed as PaaS environment?
2. We are successful in installing the OneAgent for unsupported AIX version but will deep dive monitoring work fine? because, I can see the warning message for all processes stating that,
This process isn’t fully monitored
Deep monitoring of this process has not been setup. You’re missing out on crucial process- and service-level monitoring insights. Enable monitoring as described
AK
