I am trying to make my first python extension. I am having trouble with the below plugin.py (keeps getting KeyError: ‘results_builder’. I have not had much luck finding examples of what I want to do. Not really finding any doc out there on the ruxit.api I have easily built a similar script that uses the metrics API to ingest but trying to convert that to Oneagent Extension has been challenging. You can see I have been trying several iterations of invoking the self.results_builder*.
import psutilfrom ruxit.api.base_plugin import BasePluginfrom ruxit.api.data import PluginMeasurementimport loggingimport os
# Set up logging for Windowslog_file_path = os.path.join(os.getenv(‘PROGRAMDATA’), ‘dynatrace’, ‘custom_browser_metrics.log’)logging.basicConfig(level=logging.DEBUG, filename=log_file_path, filemode=‘w’)logger = logging.getLogger()
class PythonPluginHost(BasePlugin
def initialize(self, **kwargs
logger.debug(“Plugin initialized”) def query(self, **kwargs
#pgi = self.find_single_process_group(pgi_name(‘plugin_sdk.demo_app’)) #pgi_id = pgi.group_instance_id #stats_url = “http://localhost:8769” #stats = requests.get(stats_url, timeout=10).json() results_builder = self.results_builder if not results_builder: logger.error(“results_builder not found in kwargs”) return browsers = [“chrome”, “msedge”] for browser in browsers: metrics = get_process_metrics(browser) if metrics: cpu = metrics[“CPU”] memory = metrics[“Memory”] logger.debug(f"Sending metrics for {browser}: CPU={cpu}, Memory={memory}“)
#self.results_builder.absolute(key=“custom.browser.cpu”, value=cpu, dimensions={“browser”: browser}) self.results_builder.add_absolute_result(PluginMeasurement(key=“custom.browser.cpu”, value=cpu)) #self.results_builder.absolute(key=“custom.browser.{browser}.cpu”, value=metrics[“CPU”]) #self.results_builder.absolute(key=“custom.browser.memory_percent”, value=memory, dimensions={“browser”: browser}) self.results_builder.add_absolute_result(PluginMeasurement(key=“custom.browser.memory_percent”, value=memory)) #self.results_builder.absolute(key=“custom.browser.{browser}.memory”,value=metrics[“Memory”]) else: logger.debug(f"No metrics found for {browser}”)def get_process_metrics(process_name
total_memory = psutil.virtual_memory().total # Total memory in bytes cpu = 0 memory = 0
for proc in psutil.process_iter([‘name’, ‘cpu_percent’, ‘memory_info’]): if proc.info[‘name’] and process_name.lower() in proc.info[‘name’].lower(): cpu += proc.cpu_percent(interval=1) # Allow psutil to measure CPU usage over a short interval memory += proc.info[‘memory_info’].rss # Resident Set Size in bytes memory_percent = (memory / total_memory) * 100 memory_percent = (memory / total_memory) * 100 # Convert bytes to percentage logger.debug(f"Process: {process_name}, CPU: {cpu}, Memory: {memory_percent}") return {“CPU”: round(cpu, 1), “Memory”: round(memory_percent, 1)} if cpu or memory else None# If running as a script, instantiate and queryif __name__ == “__main__”: plugin = PythonPluginHost() plugin.initialize() plugin.query()The plugin.json file for this:{ “name”: “custom.python.browser_metrics”, “version”: “1.0.0”, “metricGroup”: “custom_browser.metrics”, “technologies”: [“PYTHON”], “type”: “python”, “entity”: “HOST”, “metrics”: [ { “timeseries”: { “key”: “custom.browser.cpu”, “displayname”: “Browser CPU Usage”, “unit”: “Percent” } }, { “timeseries”: { “key”: “custom.browser.memory_percent”, “displayname”: “Browser Memory Usage”, “unit”: “Percent” } } ], “interval”: 60 }
