How do I get details of OneAgent upgrade failures with API?
Hi @kadirhan, have you had a chance to check this?
LOST_AGENT_UPGRADE_FAILED: Hosts where OneAgent has a potential update problem due to inactivity after update.
Hope it helps!
LOST_AGENT_UPGRADE_FAILED: Hosts where OneAgent has a potential update problem due to inactivity after update.Hope it helps!
