Hi guys,
We have one agent installed on more than 300 servers. We want to upgrade the one agents now and as part of that want to use some of the installation params mentioned here
mainly we want to change the location of DATA Storage and Log Path. We want to know whats the best way to achieve this ?
a) Oneagent updates via UI or automatic maintenance window - can this be used somehow to update oneagents and also change the data storage and logpath ?
b) If the only way to change the data storage and logpath is to uninstall and install a new oneagent from Linux level(i.e point a) mentioned above is not possible) then does this mean we need to perform oneagent updates wherever custom installation params are used always from linux/machine level or is it like once the custom installation params are set then new updates can be done via UI itself
