Open Discussion - Interpret trace
Hello All,
how would you interpret the bellow trace,
Bellow Queries are taking 1.5sec each,
after checking with database team, same queries are taking around 40msec.
Why its network I/O? is it because we are monitoring the calls from application server, so network time and processing are also counted?
Thanks.
Hi @Malaik
You mentioned that the same queries are taking 40ms. One query or 47/50 queries are taking 40ms? If one and you multiply 47 or 50 times then it could be 1,5 - 2 sec (1500ms - 2000ms).
Best regards,
Mizső
Yes thanks @Mizső this is what I’m thinking.
Thanks and good day.
you have around 300 db calls in this trace.
2 additional ms per db call means 0.6 seconds.
In the case of such a number of queries, I would be interested to know whether you have correctly set the cache for database queries on the application side (a very common problem on environments with Hibernate).
