Hey Everyone, looking for some advice here.
I want to build out OpenPipeline for logs and spans and wondering what the best practice is.
The end goal is to have buckets on a per service level as well as extract metrics from spans/logs and process logs as needed.
To organize things would it be best to do
a. 1 dynamic route per service → 1 pipeline per service
b. 1 dynamic route for stackenv → 1 pipeline per stackenv
I like option a because it gives us more control but option b seems easier to manage? Looking for advice thanks in advance!
Hi @calfanonerey,
From what I’ve seen in the docs and setups I’ve worked with, the choice really depends on how similar your services are in terms of log and span processing:
- Option (a) – one dynamic route and one pipeline per service – gives you fine-grained control (different extraction rules, retention, metrics, etc.) but can quickly become hard to maintain at scale.
- Option (b) – grouping by stackenv – is easier to manage and works well if the services in a stack share similar characteristics.
Personally, I’d probably go for a hybrid approach: start with stackenv-level pipelines and split out only the services that need specific processing logic. Automating pipeline creation via the Settings API can help a lot here.
That said, this is just my take based on current documentation and experience — I’d be very interested to hear how others have structured their OpenPipeline deployments and if they found a cleaner pattern!
Warm regards,
Jean
