OpenShift Dynatrace operator 1.5.1: app-mon pod fail to start for runAsUser 1001 not allowed
Hi all.
We are on Managed.
We are testing app-monitoring in OpenShift with Dynatrace OpenShift operator 1.5.1 : Dynatrace Operator release notes version 1.5.1 — Dynatrace Docs (the requirements are satisfied: Cluster v1.312.51 + AG v1.311 + OA  v1.311.72).
When a deployment try to start replicat we get this error : runAsUser 1001 not allowed, must be in the range [1001060000, 1001069999].
30s Warning FailedCreate replicaset/x0m-56854c4ffd Error creating: pods "x0m-56854c4ffd-" is forbidden: unable to validate against any security context constraint: [provider "anyuid": Forbidden: not usable by user or serviceaccount, provider "trident-controller": Forbidden: not usable by user or serviceaccount, provider restricted-v2: .initContainers[1].runAsUser: Invalid value: 1001: must be in the ranges: [1001060000, 1001069999], provider "restricted": Forbidden: not usable by user or serviceaccount, provider "nonroot-v2": Forbidden: not usable by user or serviceaccount, provider "nonroot": Forbidden: not usable by user or serviceaccount, provider "hostmount-anyuid": Forbidden: not usable by user or serviceaccount, provider "logging-scc": Forbidden: not usable by user or serviceaccount, provider "machine-api-termination-handler": Forbidden: not usable by user or serviceaccount, provider "hostnetwork-v2": Forbidden: not usable by user or serviceaccount, provider "hostnetwork": Forbidden: not usable by user or serviceaccount, provider "hostaccess": Forbidden: not usable by user or serviceaccount, provider "trident-node-linux": Forbidden: not usable by user or serviceaccount, provider "node-exporter": Forbidden: not usable by user or serviceaccount, provider "privileged": Forbidden: not usable by user or serviceaccount]
AFAIU Dynatrace Operator should not try to assign a User ID for it’s OneAgent agent / code module, because OpenShift handles automatically the assignment. OpenShift doc @ security-context-constraints-example.
Any feed back from someone on that ?
Regards.
this should be investigated in a support ticket. Attach also support archive and information regarding the Openshift version.
Could it be that setting a runAsUser value at https://github.com/Dynatrace/dynatrace-operator/blob/main/pkg/webhook/mutation/pod/v2/init.go#L75 is interfering with default OpenShift automatic uid assigment ? Doc 15.2. About pre-allocated security context constraints values.
(Yes we have a ticket open :-))
Hi there,
This is a known issue, and a fix is in progress.
While we are working on a fix, apply one of the following changes to work around the problem:
  • add spec.securityContext.RunAsUser(Group) on the POD level valid ID value can be found in the app namespace’s annotations
kind: Namespace<br>metadata:<br>  annotations:<br>    openshift.io/sa.scc.supplemental-groups: 1000660000/10000<br>    openshift.io/sa.scc.uid-range: 1000660000/10000
  • add nonroot-v2 SCC to the ServiceAccount
apiVersion: rbac.authorization.k8s.io/v1<br>kind: RoleBinding<br>metadata:<br>  name: <name><br>  namespace: <app namespace><br>roleRef:<br>  apiGroup: rbac.authorization.k8s.io<br>  kind: ClusterRole<br>  name: system<img class="lia-deferred-image lia-image-emoji" src="https://community.dynatrace.com/html/@5212909FB2CD724D8357AAB19125D03B/images/emoticons/openshift.png" alt=":openshift:" title=":openshift:">scc:nonroot-v2<br>subjects:<br>- kind: ServiceAccount<br>  name: <app ServiceAccount><br>  namespace: <app namespace>
Regards
Hi there,
Any update on this issue? Will it be fixed in the next release and if so ..any idea when it will be released?
From what I read in the work around, both seem actions that need to be performed per namespace?
So a customer with +500 namespaces need to implement this +500 times and any future deployment
The Operator release 1.6.0 includes the fix. You can already try a release candidate in any affected non-prod environment.
AFAIU this is (for now) available only throuh helm (requiering more hacky work for integration), not through OpenShift operator hub and standard operator integration.
I have used the YAML files of Release v1.6.0-rc.2 · Dynatrace/dynatrace-operator · GitHub for OpenShift (4.13):
  • openshift.yaml
  • openshift-csi.yaml
  • dynatrace-operator-crd.yaml
In the first two files I replaced the redhat image link with the one of Docker “dynatrace/dynatrace-operator:v1.6.0-rc.2”. Since redhat one does not exist.
I had to add the CRD via OpenShift gui or I got an error.
I then Added the DynaKube config for beta5 and everything is running. I can see my cluster in Dynatrace.
However, we still have the issue our GitLab runners and other deployments are getting:
ERROR: Error cleaning up pod: resource name may not be empty
ERROR: Job failed (system failure): prepare environment: setting up build pod: pods "runner-t1qz363-project-22774-concurrent-0-bzq4fg5s" is forbidden: unable to validate against any security context constraint: [spec.volumes[5]: Invalid value: "csi": csi volumes are not allowed to be used, provider restricted-v2: .initContainers[1].runAsUser: Invalid value: 1001: must be in the ranges: [1006100000, 1006109999], provider restricted: .initContainers[1].runAsUser: Invalid value: 1001: must be in the ranges: [1006100000, 1006109999], provider "nonroot-v2": Forbidden: not usable by user or serviceaccount, provider "nonroot": Forbidden: not usable by user or serviceaccount, provider "rsync-anyuid": Forbidden: not usable by user or serviceaccount, provider "hostmount-anyuid": Forbidden: not usable by user or serviceaccount, provider "elasticsearch-scc": Forbidden: not usable by user or serviceaccount, provider "logging-scc": Forbidden: not usable by user or serviceaccount, provider "machine-api-termination-handler": Forbidden: not usable by user or serviceaccount, provider "hostnetwork-v2": Forbidden: not usable by user or serviceaccount, provider "hostnetwork": Forbidden: not usable by user or serviceaccount, provider "hostaccess": Forbidden: not usable by user or serviceaccount, provider restricted-csi: .initContainers[1].runAsUser: Invalid value: 1001: must be in the ranges: [1006100000, 1006109999], provider "node-exporter": Forbidden: not usable by user or serviceaccount, provider "privileged": Forbidden: not usable by user or serviceaccount, provider "velero-privileged": Forbidden: not usable by user or serviceaccount]. Check https://docs.gitlab.com/runner/shells/index.html#shell-profile-loading for more information
The GitLab runner pods were restarted.
As soon as we uninstall DT, it works again.
Am I doing something wrong?
Hello.
We now use Dynatrace Operator release notes version 1.6.0 — Dynatrace Docs (channel:alpha  catalogsource_name:certified-operators   catalogsource_namespace:openshift-marketplace).
The issue “runAsUser 1001 not allowed” is fixed.
Regards.
We tried infra-only + app-mon, and also cloud-native full-stack (without CSI ). Fine.
