Oracle Database Extension - DDU's consumption
Hi, please can you help me understand how to calculate ddus consumption for Oracle database extension?
If I have 11 database instances on 3 servers, how should I do the calculation?
Hi @santruan,
Consumpotion depends on heavily the monitored feature sets and the db structure.
Basic information about the ingested metric DDU consumption calculation.
Example for one hour consumption for a quite big consolidated Oracle db by feature sets:
You can swith on / switch of feature sets in the Oracle extension configuration:
I hope it helps.
Best regards,
Mizső
Hi @Mizső
Understood. Thank you very much for your answer.
