Oracle Extension 3.1.3 - ORA-00904 "MAX_AUDIT_SIZE" and ORA-00942 Warnings
Hi Community,
I’m looking for guidance on an Oracle Database extension issue that we’re seeing in a pre-production environment.
Extension Version:
  • Oracle Database Extension 3.1.3
Symptoms:
The monitored endpoint is reachable and metrics are being collected, but the extension intermittently reports the following warnings:
1 ORA-00904: “MAX_AUDIT_SIZE”: invalid identifier2 ORA-00942: table or view does not exist
The warning appears as a query failure rather than a complete connection failure.
What we’ve checked so far:
  • Database connectivity is working.
  • The Oracle monitoring user permissions have been reviewed.
  • DBA team has confirmed the monitoring account has the same permissions as our production environment.
  • The issue is limited to this environment; production is not reporting the same warning.
  • We are using the standard Dynatrace Oracle extension configuration.
Questions:
  1. Has anyone seen MAX_AUDIT_SIZE related errors with Oracle Extension 3.1.3?
  2. Is this typically caused by:
    • Oracle version differences?
    • Auditing configuration differences?
    • Missing Oracle objects/views?
    • Extension compatibility issues?
  3. Is there a way within Dynatrace to identify the exact SQL query behind this warning?
  4. Are there specific Oracle audit-related views or features that must exist for this metric to work?
  5. Has anyone successfully resolved a similar combination of:1 ORA-00904: MAX_AUDIT_SIZE2 ORA-00942: table or view does not existand if so, what was the root cause
Any troubleshooting advice or experiences would be greatly appreciated.
Thanks in advance!
Hi @DB1
I’ve seen similar errors when the extension executes queries against Oracle views or columns that are not available in a particular database version or configuration.
ORA-00904: MAX_AUDIT_SIZE usually indicates the extension is referencing a column that doesn’t exist in that Oracle version or audit configuration.
ORA-00942 typically means the monitoring user cannot access a required table/view, or the object doesn’t exist in that environment
To see the exact SQL statement failing on the database: Go to the ActiveGate running the Oracle extension and check the log file.
If you can identify the missing table/view or the query containing MAX_AUDIT_SIZE, that will likely point to the root cause fairly quickly.
Sujit
