Is there a way to specifically pick the order I want the split by to be displayed?
For example I want the value that’s blue at the very top followed by red then yellow
To me it looks like it’s alphabetical?
Thanks.
Yeah but as far as I’m aware if I have two fields and I want one field displayed on top of the other, it’s not possible right? in your screenshot if there was another series called storeC could I be able to display storeC ABOVE storeB?
Yea, it does seem to work with series overrides, whatever I select from drop down seems to be showing up on the top when I have multiple options to select
Testing it out in my environment, if using a bar chart you can choose the order by using the sort function in DQL. For example the bellow is ordered by hostname:
timeseries avg(dt.host.cpu.usage), by:{host.name}
| sort host.name desc
If I then sort ascending the order flips as expected. Removing the sort, it appears to be reverse alphabetical by default.
