My company is trying to look to possibly leverage the Ownership features in Dynatrace. Our record of truth for ownership today is in our ServiceNow CMDB. We also have the integration between Dynatrace feeding data (entities etc) into the CMDB. I wanted to know if anyone today is leveraging the ServiceNow CMDB to push the Ownership information into Dynatrace. Since there is an option to leverage an external ID in Ownership to populate data via an API. Has anyone attempted this type of integration?
Hi @steventorrestam , were you able to find a solution for your use case maybe? Thank you!
This is something I am currently building from the CMDB with another user.
The plan is to use the Dynatrace workflows to query external data through JavaScript, and output those into a useable format, the Ownership API JSON body can then be populated by.
In the Dynatrace workflows you can query the ServiceNow API and pull back CMDB data from the ServiceNow API, then use that data to populate the Ownership autonomously.
I will update more once I get this working next week ![]()
Lawrence
Hello @LawrenceBarratt ! I’m wondering if you can provide any more info on this? Are you able to provide the workflow you created so we can mimic it?
Hi Lawrence, any updates on your progress? I am very interested to know more. Thanks.
Hello. Apologies, i am still waiting on some tokens from ServiceNow to capture the CMDB data and Business Applications.
I’ll update by the end of the week on progress and a solution 🙂
feel free to screen through the recently updated documentation of service now for workflows: ServiceNow Connector to integrate with Workflows — Dynatrace Docs
or how to import ownership teams from Service Now groups or Microsoft Entra ID (Azure Active Directory).
Best,
Gerhard
and here the missing link to the teams-importer workflow action: Ownership app — Dynatrace Docs
