Good Morning.
Is it possible to parameter the installation of the OneAgent?
I look especially for another installation path than /opt and another directory for the dump savings.
The reason is, that our legacy partition layout is a way to restrictive and the filesystem is a way to small.
Thank you in advance for your time and answers.
Best,
Jan
Hi Jan-Hendrik,
You can find the information here:
https://help.dynatrace.com/get-started/installatio…
You will need the INSTALL_PATH parameter.
Kind regards,
Chris
Hej @Chris G.
Thank you very much … I think, am blind. ,-( This is, what I need.
I am not able to manage the dump savings or disable the crash dump overall, right?
Best regards,
Jan
How to automatically determine the token used during the oneagent installation (parameter
TENANT_TOKEN)
Regards
Hello Gautier,
you will find that information in the paragraph describing TENANT_TOKEN parameter on the following help page:
https://www.dynatrace.com/support/help/shortlink/command-line-install
You can parse the retrieved json object and get TENANT_TOKEN from there.
Regards
Tomasz
Tomasz,
I’m using Dynatrace Managed and this feature seems not to be yet available on my cluster. It’s coming with which sprint ?
That should work for you as well. Just use it in the tenant’s context. For instance:
https://<your_cluster_hosname>/e/<tenant_id>/api/v1/deployment/installer/agent/connectioninfo?Api-Token=<API_TOKEN>
Api-Token can be retrieved from the installer page:
