marusla
1
Hello, i try to parse a xml, but i dont know how to doing, maybe do you have a steps, im trying with xml:xml but just extract a few lines
Fecha: 2025-09-08 00:33:33
Respuesta: Casos 0 de Casos Tiempo: 0
Request: <caso>
<infoBasica>
<origen>C</origen>
<mid>112222</mid>
<tid />
<idAsesor>mflores</idCliente> <appPeticion>
Tipos</appPeticion> </infoBasica> <detalledelCaso>
@marusla Have you tried the DPL ? Below video cover some use cases around parsing json content which might help
marusla
3
thanks, finally i parse the logs, using data and eol commands , thanks, data for parse all the log, and eol for moving to next line
