I have this query and would like to find out which endpoints fall within the 98th percentile:
timeseries {
totalCalls = sum(log.prgoffer.foapi.baminfo.httpmethod,
filter: isNotNull(endpoint)),
successCalls = sum(log.prgoffer.foapi.baminfo.httpmethod,
and matchesValue(baminfo.exception,“OK”)),
by:endpoint
interval: 5m
| fieldsAdd successRatio = successCalls[] / totalCalls[] * 100
| fieldsRemove successCalls, totalCalls
thanks for all support
@enrico_afkl You can try the “arrayPercentile”, please see below
Thank you very much! With this query, I now have the following:
timeseries total=avg(log.prgoffer.foapi.baminfo.soap.duration) by: {baminfo.provider}
| fieldsAdd p99 = arrayPercentile(total, 99)
| fieldsRemove timeframe, interval, total
A chart showing the 99th percentile by category.
Is it possible to see how the P99 has changed over time for each provider? (Using a line chart)
@enrico_afkl Yes, you might need to modify the DQL a bit, please try the below
timeseries p99=percentile(log.prgoffer.foapi.baminfo.soap.duration, 99) , by: { baminfo.provider }
I and thanks for your answer
I thought that was the right solution but when I tried I had “no records” answer whereas with the previous query I do have values within the same range so I am puzzled.
do you understand why?
@enrico_afkl The data that you are querying , is that a timeseries data? What if you try to get a average , do you see data?
timeseries avg(log.prgoffer.foapi.baminfo.soap.duration) , by: { baminfo.provider }
I did this for the first query, but now i would like to have the evolution in time with a line chart
@enrico_afkl Earlier DQL should work for line chart , you just need to change the visualization . Could you please elaborate the issue you are facing for better understanding ?
hello @p_devulapalli ,
I vcan see data but I’d like to have percentile and not just the average
thanks a lot for your help
@enrico_afkl I am bit unsure why you are not able to see the data for percentile, it should display similar to average . Please open up a ticket with support, they might be able to guide you correctly.
