Summary: This post describes which areas to review for an infrastructure health check in Dynatrace Managed, including cluster status, disk space, performance metrics, and log files.
Hi Team,
Do you have any scripts, commands, or options that will help us know the Dynatrace Managed health status on a daily basis? We would like to have the status of the following items on a daily basis in the report.
1) Cassandra & Elastic Backup
2) All ActiveGates are up and running fine
3) All Dynatrace node critical processes are up and running fine.
4) Node storage utilization.
5) Access to the console is fine.
1) Cassandra:
\launcher\dynatrace-notetool.sh status
Elasticsearch:
curl <ip_address>:9200/_cluster/health
2) ActiveGate
curl https://<ip_address>:8443/rest/state > -k -i
3) All node services
\launcher\dynatrace.sh status
4) Storage
do it on your own currently - with `du` command
Public REST API to be exposed in the future.
5) Access to console
to check server:
curl
https://<ip_address>:8021/rest/health -k -i
If server is RUNNING then console should work as well. In case you want to be sure you could maybe create a Selenium test or curl/wget ?
Hi @Radoslaw S.,
A question about 5)
Is there an overview of the different responses /rest/health can give? Can this check be used to see that a node is about to restart?
