Hi Team,
I’m learning the synthetic monitor performance thresholds part. And I’m facing one problem regarding it. It’s this:
If I set the threshold as “total duration of all event” when I create one synthetic monitor, when the problem will generate? 3 failures of 5 execution or the issue occurred at once?
@Quirina,
A problem will be generated according to a sliding window of 5 measurements, when 3 of them are breached.
I’ll give several examples below (hope I get them right
). The threshold for these examples is 60 seconds, and assumes no measurements before t0, or all of them below 60 seconds:
- Generated at t2
t0: 65 seconds
t1: 66 seconds
t2: 61 seconds
- Generated at t4
t0: 55 seconds
t1: 61 seconds
t2: 70 seconds
t3: 55 seconds
t4: 65 seconds
- Generated at t6
t0: 62 seconds
t1: 55 seconds
t2: 70 seconds
t3: 55 seconds
t4: 58 seconds
t5: 63 seconds
t6: 65 seconds
- Generated at t9
t0: 61 seconds
t1: 61 seconds
t2: 55 seconds
t3: 58 seconds
t4: 59 seconds
t5: 62 seconds
t6: 61 seconds
t7: 55 seconds
t8: 56 seconds
t9: 65 seconds
Please note that with the configuration you have, 10 seconds, there will be a problem almost immediately, as Dynatrace says that over the last 24 hours the average was 54.31 seconds. I do understand though that 10 seconds is the default value, and you haven’t changed it yet
Thank you so much for your answer and detailed description. You’re right. The 10s in the 2nd image I pasted is the default value.
Actually, I just confuse the description of the document in red square and orange line part. I just want to know if any one time execution violate the threshold I configured. Does it generate the problem immediately or will generate after 3 violate executions of 5?
