<br><span>// Top-level build file where you can add configuration options common to all sub-projects/modules.<br></span><span><br></span><span><br></span> buildscript <span>{<br></span><span><br></span> repositories <span>{<br></span> google()<br> mavenCentral()<br> flatDir <span>{<br></span> dirs <span>'libs'<br></span> <span>}<br></span><span> }<br></span><span><br></span><span><br></span> dependencies <span>{<br></span> classpath <span>'com.android.tools.build:gradle:8.3.1'<br></span> classpath <span>'com.dynatrace.tools.android:gradle-plugin:8.+'<br></span> <span>}<br></span><span> }<br></span><span><br></span>plugins <span>{<br></span> id <span>'com.android.application' </span>version <span>'8.3.1' </span>apply <span>false<br></span> id <span>'com.android.library' </span>version <span>'8.3.1' </span>apply <span>false<br></span> id <span>'org.jetbrains.kotlin.android' </span>version <span>'1.9.23' </span>apply <span>false<br></span> id <span>'com.dynatrace.instrumentation' </span>version <span>'8+' </span>apply <span>true<br></span><span>}<br></span><span><br></span> apply <span>plugin</span>: <span>'com.dynatrace.intrumentation'<br></span> dynatrace <span>{<br></span> configurations <span>{<br></span> <span>mainConfig </span><span>{<br></span> <span>autoStart </span><span>{<br></span> applicationId <span>'xxx'<br></span> beaconUrl <span>'xxx'<br></span> <span>}<br></span> userOptIn <span>false<br></span> agentBehavior.startupLoadBalancing <span>true<br></span> sessionReplay.enabled <span>false<br></span> <span>}<br></span><span> }<br></span><span> }<br></span><span><br></span>allprojects <span>{<br></span> repositories <span>{<br></span> google()<br> mavenCentral()<br> <span>}<br></span><span>}<br></span><span><br></span><span>tasks</span>.register(<span>'clean'</span>, Delete) <span>{<br></span> delete <span>rootProject</span>.<span>buildDir<br></span><span>}</span>
You have a typo in the apply statement. The “s” is missing in “instrumentation”
apply plugin: 'com.dynatrace.instrumentation'
You are also adding the plugin two times: Via the “plugins” block and via the apply statement.
I would recommend to only add the Dynatrace Android Gradle plugin once. You can either use
plugins {
id 'com.dynatrace.instrumentation' version '8.+'
or
buildscript {
dependencies {
classpath 'com.dynatrace.tools.android:gradle-plugin:8.+'
