Polling finished with issues for endpoints: xxx.yyy.zzzz:1433/master
I have created a Dynatrace sql query extension as mentioned in the Youtube Video A Practical Guide to SQL Extensions with Dynatrace - YouTube.
After creating and signing the extension, I am getting the below error in the logs.
warn
2025-01-21 14:59:36.834 SFM Event
ContentPolling finished with issues for endpoints: xxx.xx.xx:1433/master
warn2025-01-21 14:58:37.010SFM EventContentEndpoint: xxx.xx.xx:1433/master group ‘Latest data’ did not produce any metrics. Subgroups will not be polled.
Below is the source code:
version: "0.0.4"
minDynatraceVersion: "1.279.0"
author:
metrics:
  - key: my.sql.status.value
    metadata:
      displayName: My Values
      unit: Count
sqlServer:
  - group: Latest data
    featureSet: Latest
    interval:
      minutes: 1
    ingest: metrics
    query: >
      select count (id) as count
      from master.chart WITH (NOLOCK) where
      creation_date > DATEADD(minute, -15,  GETDATE())
    metrics:
        value: col:count
    dimensions:
      - key: stat_name
        value: const:latest
How can i fix it?
The connection details seem to be fine. The same query and database were used in fetching the data using custom.db.query extension. It got deprecated. that is why I have created a new extension.
The error message indicates that the query didn’t return any data or that there was something wrong with it.
The code looks fine at first glance, so if you’re 100% sure that the query is returning data for the user you have configured in the extension, then your next step should be to get a support archive for the ActiveGate which is running that extension (or going into the AG directly) and having a look into the logs /remotepluginmodule/log/extensions/datasources/<your-ext-name>.
There should be some more info on what happened with your query. Either that it failed or that it returned 0 rows.
