Hello All, I would like to install OneAgent via menu Deploy Dynatrace → Install OneAgent → Kubernetes / Openshift.
I have condition as follows:
- 1 Dynatrace Managed Cluster
- 1 Cluster ActiveGate with public address
- EKS cluster that cannot directly connect to Dynatrace Managed Cluster
Is it possible to define the Cluster Active Gate address on dynakube.yaml? Or is it another workaround so the EKS could be monitored on Dynatrace Managed Cluster?
Thank you.
