Hello community,
I am needing to test an API and WITE Data to record. (Its a test record in our production env). Doing this is fine, however, the next time I run the same test, I get an error that the data exists.
Can I add a post execution script to validate that the data was correctly added (read the response) and then run a 2nd http api test to delete the data we just added. If the data was not written, I do not want to run the 2nd script, but send an alert instead. (want to avoid repearing failures over and over on a production record)
This proved that my API’s are available, working, writing, deleting etc.
There are 20-30 different scenarios we need this to take place as the majority of the services we interact with are SaaS and we have no records of logs/events to tell us when something breaks.
Your help is appreciated.
Greg
