practical question about custom metrics and mz
Hello who can help me?
I have created a metric based on log lines having a certain attribute. With this I want to create an event with Davis abnomaly detection.
Is there any way to get this event/problem in a MZ?
I have tried many options…
KR Henk
Hey @henk_stobbe ! I’m assuming you have already built the metric extraction. When you created that, it should have asked you to name it. You should be able to find that named metric in your data explorer. If you can see it in the Data Explorer, then you should be able to create the Davis Anomaly Detector for the alert overall.
In order to get this metric associated with a management zone, or the new segments, you will need to add it in using Dimensions with the Management Zones:
Hope this helps!
Hi Chad,
Thanks for your reply, I also added a MZ with below selector:
but still the problems all end up in:
what am I doing wrong )-;
KR Henk
https://community.dynatrace.com/t5/Open-Q-A/Map-Custom-Metric-to-Management-Zone/m-p/207706
Sorry, I now notice the metric is in the MZ, but I assume when a Problem is created this info is not used?
I see, you are looking to link the entity in the Problem Card? Try to build your DAD with DQL where it enriches the data to outline the source etc.
