Predict CPU Usage
I am new to Dynatrace and its API’s, I am trying to Predict  the CPU Usage over the next few days.
Can someone throw light on what are the steps involved in to achieve the same?
Thanks in advance.
I believe you should use this api  and know your prediction, make sure adding the parameter predict=true to this API request will help you get desired results with your timeseries metrics.
Refer this below blog as well
How to ask your monitoring system about the future | Dynatrace news
