Prevent javascript execution to users
Hi Dynatrace community,
Is there a way to prevent users to execute javascript in apps? i.e Dashboards, workflows, notebooks etc…
The use case here is, we would need to prevent an user to create a javascript tile in the mentioned apps (to avoid malicious intents). Is there a permission in the policies for this?
The second use case is, can we prevent users to create a javascript tile but they can consume a dashboard/notebook/workflow that an user with elevated permissions have created?
Thanks!
Best regards,
Paco
Hi Paco,
I think you can define a read-only IAM policy to the objects you need to.
Ex.:
ALLOW settings:objects:read, settings:schemas:read WHERE settings:schemaId IN (“builtin:dashboards.general”,“builtin:dashboards.presets”,“builtin:dashboards.image.allowlist”);
ALLOW automation:workflows:read
However, someone may propose a more complete solution than mine.
Hope it helps anyway.
Elena.
