Preventing Events from Merging into a Single Problem in Dynatrace
Hi all,
I’m currently experiencing an issue where multiple events are being merged into a single problem in Dynatrace. I would like each event to generate a separate problem instead.
How can I configure this to ensure the events remain separate?
Hello @Eyad ,
you can explore the option "dt.event.allow_davis_merge: false" from this document here
