PRO TIP - Business hours in Dynatrace for SLOs or metric events
Hi @Julius_Loman .
We have version 0.0.12 on one client and we have a few questions:
Is version 0.0.17 added support for python 3.14?
Is there any documentation that outlines the steps to update it?
Hi @JAR1 ,
yes, version 0.0.17 was updated with latest extension SDK and works with Python 3.14. (ActiveGate 1.333+).
Thank you so much for your help, @Julius_Loman !
I have a question about updating the extension: we have the initial version installed and working fine. When it was installed, a self-signed certificate was generated and uploaded to the AG.
The question is, when updating now, do I need to generate a new certificate and upload a .pem file to the AG? Or can I upload the new code?
Thanks again
BR
JAR
If you have built on your own, you can reuse the certificates you have. However, you can use the built version that is in the releases, but you must upload the certificate that provided in the release to your environment and the active gate.
