Use Davis AI model for SLO management
so we have an application which process transaction, i.e somehwere from 100messages pers to 1000 msgs per sec, this number can wary depending on day/time of the day, and we use DAViS for Anomoly detection based on seasonal pattern, which identifies for potential problems if it thinks transaction are less as compared to Historical day and time, is there a way I can use that for SLO computation.
Hello @rishisingh1210
KFA useful Dynatrace resources:
Hoping it helps.
KR,
Peter
Hey @rishisingh1210
Since Peter already provided some publicly available material on that topic, I wanted to reach out to you, too.
First, it should be possible, but I need more details to confirm.
- Are you on managed/SaaS classic or the latest Dynatrace SaaS platform (using Grail)?
- can you share the metric that is used for anomaly detection?
- What’s your goal for using an SLO on the process transactions? Do you expect a certain minimum amount aggregated over, e.g., one week? In other words, how would you like to interpret the SLOs? What information do you want to extract from the SLO value?
I’m just asking this because maybe leveraging other functionalities, such as the Site Reliability Guardian, would be beneficial here as well.
Gerhard
