Pro Tip - Markdown Tile Links
We had a use case where I had to formulate at suite of dashboards and link them to each other as users want a single click to get to where they need to be. As a result I made a dashboard with placeholders being the Markdown tile, then when I created the sub dashboard I went back to link the Dashboard ID to the Markdown tile.
Instead of retyping the value in the [ ] and instead of putting the brackets around the value that was present, I copied the URL/Dashboard ID, then edited the markdown tile, Highlighted the text I wanted as the link, Clicked the Link Icon, Then Ctrl V to past in the URL/Dashboard Values.
It makes the process a bit quicker especially if you have a bunch that need to be done.
Great Tips!
