Hi Dynatracers,
We are using Dynatrace Network Availability Monitors (NAM) to collect the availability of network devices through Ping/ICMP, DNS, and TCP checks. NAM supports ICMP, TCP, and DNS monitor types to validate the availability of hosts, devices, and services from a network perspective.Example of Powerful DQL I use :
| timeseries availability = avg(dt.synthetic.multi_protocol.request.availability), by: { dt.entity.multiprotocol_monitor, multi_protocol.request.target_address, request.target_address } | fieldsAdd targetAddress = coalesce(request.target_address, multi_protocol.request.target_address) | lookup [ fetch `dt.entity.network:device` | expand dt.ip_addresses | fields deviceId = id, deviceName = entity.name, lookupIp = dt.ip_addresses ], sourceField: targetAddress, lookupField: lookupIp, fields: { deviceId, deviceName } | fieldsAdd monitorName = entityName(dt.entity.multiprotocol_monitor) | fieldsAdd deviceName = coalesce(deviceName, "No matching network device") | fields monitorName, deviceName, deviceId, targetAddress, availability |
Result :
Remark :
Reachability is the key KPI because it measures whether the target network device or service is actually reachable from the monitoring location, regardless of the underlying protocol used: ICMP, DNS, or TCP.
Reachability (%) = average availability of NAM requests over the selected timeframe
Why Ping, DNS, and TCP Are Useful
- Ping / ICMP checks whether the device is reachable on the network.
In simple terms: Can I reach the device? - DNS checks whether the device or service name can be resolved correctly.
In simple terms: Does the hostname resolve to the expected IP address? - TCP checks whether a specific port is open and accepting connections.
In simple terms: Is the expected service actually reachable on its port?
Conclusion : Ping validates network reachability, DNS validates name resolution, and TCP validates service-level accessibility. The DQL lookup then connects these checks back to the corresponding Dynatrace network device entity.
Hope it helps,
Cheers!
