PRO TIP - New Hex Code Color Picker!
Some of you may be aware of this but in Cluster Version: 1.257.164.20221230-102519 you can dynamically set your color overrides without needing to get the hex code, you can also use the eye dropper as well to select your color.
Steps:
First set your Data explorer chart with the data you want to showcase.
1 - Select Add color override
2 - Click the color swatch
3 - Click the larger selected color swatch
4 - Select the eye dropper
5 - use the eye dropper to grab the color you want to use
Great tip!  Wonder why not in release notes?
