Every now nad then the question might arrise “What defined app does this report to?” This questions is easily solved!
Go to the webpage in question, then inspect the page and expand the header, scroll down till you see the Ruxit Injection:
Highlighted in red if your Application ID, if you pull that and paste it into your URL (replace the ID on the URL when your on a defined application in the UI) and it will take you to the defined application.
Also as a added bonus, in the end of the string you will seethe applied JavaScript version applied to the URL as well.
I hope this little tip/trick helps you all!
