Pro Tip with DQL "DQL Builder & Validator dashboard"
Team,
Please see this great DQL dashboard that was created by Dynatrace (everyone can download!).  Glad I checked Linkedin.
Hello Dynatrace universe! Sharing another tool to help you get started with hashtag#Dynatrace hashtag#GRAIL. With this DQL Builder & Validator dashboard (LinkedIn) you can easily search for any available data objects (entities, cloud, logs, spans, problems, etc.) and have a standard hashtag#DQL ready with all available fields. If you would ask what fields are available for a data table in GRAIL, you can easily find that list or pick certain fields that you need. There’s also a custom DQL validator to check if the query is correct. Thanks to Sowmiya Venkiteswaran and Bradley Danyo for assisting with this dashboard! Grab your copy from Dynatrace Playground here, LinkedIn
