Problem dynatrace oneagent automatic service start
Hi Guys,
We have problem dynatrace oneagent automatic service start,but we stop service.We had restart systems 2 day ago.
Thank you.
what exactly is your problem here? OneAgent should automatically create systemd units to start itself after a reboot. Is that not the case with your installation?
best regards
Franz
Hi Franz,
Thank you for respond .We stop service and not used monitor.We want to know dynatrace service start.
you can use the following commands to start, stop and check the status of the oneagent.
Hi Franz, Can you share any doc or possibly elaborate on this. Some of our OneAgents are not starting after a host gets rebooted and I’m trying to find some doc to send to our OS team to investigate…
