Dear Community,
I have a question, In my org we have a requirement to suppress problem notification for a specific workload in a k8s cluster.
I know we can disable notification from anomaly settings but for the namespace not for the workload.
e.g. consider I have a namespace: test-namespace in this namespace I have 3 workloads
workload 1
workload 2
workload 3
I want to disable all the problem notification’s coming only and only for workload 1 in namespace ‘test-namespace’
So Please let me know how can I achieve this?
1. Don’t suggest to migrate workloads to different namespace and disable namespace events.
2. Don’t suggest filtering events these are not considerable solutions.
Hi @skhamitkar
You have many options:
Use the entity filter for the specific workload in the Manatenance window settings:
OR create an autotag, tag those workloads which should the scope of Manintenance Window. You can change this dinamically later.
Create an Management Zone for the above created tag:
Put this MZ to filter the Manitenance Windows, or use simply the tag in the first step without MZ creation:
I hope it helps.
Best regards,
János
Dear Mizso, Thanks for the suggestions but I dont want the problem notfications to be suprressed during meintenece winows I want those to be suprressed forever and for the specific workloads.
@CommunitySB Any solution available for the usen case mentioned?
